Hi all
I’m currently working on controlling a vehicle to follow a reference path using MPC, targeting the tracking of x, y, ψ, vx, and vy. While doing this, I did not specify a cost type, but provided the external cost and Hessian manually, and it worked very well. However, when I explicitly set cost_type = "EXTERNAL" and ran the same settings, it didn’t perform as expected. I’d appreciate it if you could explain why.
Also, another issue is that when using the default settings, changes in the QP weights don’t significantly affect performance, which is problematic.
Code
# ocp.cost.cost_type = "EXTERNAL"
# ocp.cost.cost_type_e = "EXTERNAL"
Q_n = diag([config.mpc.tqx_n, config.mpc.tqy_n, config.mpc.tqpsi_n, config.mpc.tqvx_n, config.mpc.tqvy_n, \
config.mpc.tqomega_n,config.mpc.tqdelta_n, config.mpc.tqD_n])
Q_tn = diag([config.mpc.tqx_n, config.mpc.tqy_n, config.mpc.tqpsi_n, config.mpc.tqvx_n, config.mpc.tqvy_n, \
R_n = diag([config.mpc.trdD_n,config.mpc.trddelta_n])
ref_psi_e = ref_psi*config.mpc.tx_psi
ec = ca.sin(ref_psi_e)*(X - ref_x) - ca.cos(ref_psi_e)*(Y - ref_y)
el = -ca.cos(ref_psi_e)*(X - ref_x) - ca.sin(ref_psi_e)*(Y - ref_y)
epsi = psi - ref_psi
E_state = ca.vertcat(
X-ref_x,
Y-ref_y,
config.mpc.tx_psi*(psi - ref_psi),
config.mpc.tx_vx*(vx - ref_vx),
config.mpc.tx_vy*(vy - ref_vy),
omega, delta, D
E_input = ca.vertcat(
dD,
ddelta
ocp.model.cost_expr_ext_cost = \
ca.mtimes([E_state.T, Q_n, E_state]) + ca.mtimes([E_input.T, R_n, E_input])
ocp.model.cost_expr_ext_cost_e = \
ca.mtimes([E_state.T, Q_tn, E_state])
# Custom Hessian (state and control)
H_stage = 2 * ca.blockcat([[R_n, ca.MX.zeros(nu, nx)],
[ca.MX.zeros(nx, nu), Q_n ]])
H_term = 2 * Q_tn
ocp.model.cost_expr_ext_cost_custom_hess = H_stage
ocp.model.cost_expr_ext_cost_custom_hess_e = H_term
Thanks ![]()
