in examples/acados_matlab_octave/generic_external_cost it is demonstrated how to use C-functions for costs, gradient, and Hessian. This works fine in Matlab.
Uncommenting the last line of code which should generate the templated C-code fails and the last part of the error message is
gcc: error: pendulum_cost/pendulum_cost_ext_cost_fun.c: No such file or directory
gcc: error: pendulum_cost/pendulum_cost_ext_cost_fun_jac.c: No such file or directory
gcc: error: pendulum_cost/pendulum_cost_ext_cost_fun_jac_hess.c: No such file or directory
gcc: error: pendulum_cost/pendulum_cost_ext_cost_e_fun.c: No such file or directory
gcc: error: pendulum_cost/pendulum_cost_ext_cost_e_fun_jac.c: No such file or directory
gcc: error: pendulum_cost/pendulum_cost_ext_cost_e_fun_jac_hess.c: No such file or directory
make: *** [Makefile:101: example] Error 1
Error in ocp_generate_c_code (line 226)
acados_template_mex.compile_main()
Error in acados_ocp/generate_c_code (line 181)
ocp_generate_c_code(obj)
Error in external_cost_example_ocp (line 172)
ocp.generate_c_code;
Is this a bug?
Is there a possibility to use C-Functions for discrete-time dynamics as well (and generate templated C-code)?
No, the template based interface never supported C Functions other than the standard CasADi ones.
Unfortunately not yet.
It would definitely be an interesting feature for several applications.
If I was to add this possibility, I would probably only do it from Python in the template based interface.
Do you think it is a lot of effort to make this possible in Matlab? Could you give me a hint what has to be changed?
I guess implementing this feature for the discrete-time dynamics is more involving, right? Therefore, I would like to try it with the cost function first, in order to see if has a noticeable impact on the performance.
I thought you are mainly using the Python interface. Or is that not true anymore?
In this case, it would actually be easier to add this feature there, since the Native MEX and template based MEX interface actually don’t share a lot of code.
One should really use soemthing like cost_ext_fun_type, dynamics_ext_fun_type, constraints_ext_fun_type where all of them are either generic or casadi.
The current way it is done in Matlab is not really clean, since one states ext_fun_type = 'generic', but dynamics and constraint external functions are still CasADi generated.
Pass the name of the file to the acados_mex_template object, it has to be included in the compilation process
I am currently working on this topic and have a first running version in my acados fork. I successfully tested it with the example mentioned at the top of this thread. Now I have questions about the C-cost function of this example: void ext_cost(void **in, void **out, void *params)
Is it always the case that in is an array of two BLASFEO_DVEC_ARGS pointers and out contains pointers to a scalar (costs), a BLASFEO_DVEC, and a BLASFEO_DMAT? Why are the input types _ARGS and the outputs not?
From my debugging output in the cost-function it seems that params is simply a double array. Is that correct?
In case I wanted to extend that to enable C-functions for discrete-time dynamics:
I’ve looked at the example in examples/c/no_interface_examples/mass_spring_nmpc_example.c and there the signature for the dynamics is: void disc_model(void *fun0, ext_fun_arg_t *type_in, void **in, ext_fun_arg_t *type_out, void **out)
There are additional arguments for input and output types. Why is this not necessary for the cost functions (there the type arguments are missing)?
