Hello there,
I tried creating an OCP with parametric cost functions, but when I tried to set the parameters using
AcadosOcp.set(), I got the following error:
acados_update_params: trying to set 0 parameters for external functions. External function has 17 parameters. Exiting.
I actually got the same one when I ran acados/examples/acados_python/tests/test_parametric_nonlinear_constrain_h.py.
Is that normal ?
Thanks a lot for your help.
Tudor
FreyJo
October 20, 2022, 7:34am
2
Hi Tudor,
the test definitely works for me and on our CI pipeline.
Did you modify the test in some way?
If so, can you clearly state what you modified?
I did not modify the file, but I have actually built acados from a slightly older commit (44ddf35db7fa11f26dfc36d5c9b0f3e30343530e, posted on sept 28) as I had trouble building acados with the latest commit. Should I try to ?
Tudor
P.S.: I should mention I am using acados on a M2 Mac, so maybe there are some deeper bugs coming from that
FreyJo
October 20, 2022, 11:17am
4
It might really be specific to your system.
Somehow
value_.shape[0] is 0 for you in this line:
stage = c_int(stage_)
# treat parameters separately
if field_ == 'p':
getattr(self.shared_lib, f"{self.model_name}_acados_update_params").argtypes = [c_void_p, c_int, POINTER(c_double)]
getattr(self.shared_lib, f"{self.model_name}_acados_update_params").restype = c_int
value_data = cast(value_.ctypes.data, POINTER(c_double))
assert getattr(self.shared_lib, f"{self.model_name}_acados_update_params")(self.capsule, stage, value_data, value_.shape[0])==0
else:
if field_ not in constraints_fields + cost_fields + out_fields:
raise Exception(f"AcadosOcpSolver.set(): '{field}' is not a valid argument.\n"
f" Possible values are {constraints_fields + cost_fields + out_fields + ['p']}.")
self.shared_lib.ocp_nlp_dims_get_from_attr.argtypes = \
[c_void_p, c_void_p, c_void_p, c_int, c_char_p]
self.shared_lib.ocp_nlp_dims_get_from_attr.restype = c_int
dims = self.shared_lib.ocp_nlp_dims_get_from_attr(self.nlp_config, \
I hope you can debug this a bit further on your system.
I debugged the code to inspect value_.shape[0] and it is 42 just as it should be . Could the arguments not be in the right order ?
FreyJo
October 20, 2022, 4:11pm
6
I think this was the issue:
acados:master ← acados:fix_python_param_set
opened 04:10PM - 20 Oct 22 UTC
Please let me know if that solves it for you.
Yes everything runs as it should, thank you very much for your quick corrections
