OCP solver fails after adding nonlinear constraint
Hi,
I think the term allocation is used in a confusing way in your post.
I changed the title of this thread to
“OCP solver fails after adding nonlinear constraint”
You will need to initialize the solver explicitly, for this problem formulation.
The default initialization is zeros, and an sqrt() constraint can not be linearized at 0.
Cheers!
