Hi, i’m reporting the error that i have when i generate a problem with many parameters.
As stated in: Error on the s-function block
when i generate a nlp problem with more than 10000 parameters, it will return me an error.
I share the code.
clear all
clc
is_parametric = 1;
import casadi.*; % Import CasADi library
Theta=ones(10000,7);
dXdt=ones(10000,1);
% Step 2: Define problem variables
eps=casadi.SX.sym(‘eps’,7);
if is_parametric
dXdtcas = SX.sym(‘dXdt’,size(dXdt));
if is_parametric
Thetacas = SX.sym(‘Theta’,size(Theta));
% Cost function with regularization
lambda = 1e-3; % Regularization term
f = abs((Thetacas * eps - dXdtcas)’ * (Thetacas * eps - dXdtcas));
% Constraint bounds
g = [eps(1);eps(2);eps(3);eps(4);eps(5);eps(6);eps(7)];
glb = [0.001;50;-5000;70000;-700000;-0.05;-0.001];
gub = [0.002;100;-3000;100000;-500000;-0.01;0];
% Step 3: Model setup
model = AcadosModel();
model.name = ‘Constr_SINDy_7’;
model.x = eps;
model.f_expl_expr = casadi.SX.zeros(length(model.x),1);
if is_parametric
model.p = vertcat(Thetacas(:),dXdtcas(:));
% Cost and constraints
ocp = AcadosOcp();
ocp.name = ‘SINDy7_solver’;
ocp.model = model;
ocp.cost.cost_type_e = ‘EXTERNAL’;
ocp.model.cost_expr_ext_cost_e = f;
ocp.model.con_h_expr_e = g;
ocp.constraints.lh_e = glb;
ocp.constraints.uh_e = gub;
ocp.cost.cost_type_0 = ‘EXTERNAL’;
ocp.model.cost_expr_ext_cost_0 = 0;
ocp.cost.cost_type = ‘EXTERNAL’;
ocp.model.cost_expr_ext_cost = 0;
% Solver options
ocp.solver_options.tf = 1;
ocp.solver_options.N_horizon = 1;
ocp.solver_options.nlp_solver_type = ‘SQP’;
ocp.solver_options.nlp_solver_max_iter = 1000;
ocp.solver_options.nlp_solver_tol_stat = 1e-2;
ocp.solver_options.nlp_solver_tol_eq = 1e-2;
ocp.solver_options.nlp_solver_tol_comp = 1e-2;
simulink_opts = get_acados_simulink_opts;
simulink_opts.inputs.x_init = 1;
simulink_opts.outputs.cost_value = 1;
simulink_opts.outputs.KKT_residual = 0;
simulink_opts.outputs.KKT_residuals = 1;
ocp.simulink_opts = simulink_opts;
% Solver creation
Now if the Theta and dXdt matricies have rispectively a dimension of (1000x7) and (1000x1) it will works, instead with the dimensions in the code it will give me this error:
Warning: self.parameter_values are not set.
Using zeros(np,1) by default.
You can update them later using set().
In AcadosOcp/make_consistent (line 131)
In AcadosOcpSolver (line 51)
In CSINDy_7 (line 73)
OCP without constraints on initial state detected.
found compiled acados MEX interface
Error using acados_template_mex.compile_ocp_shared_lib
Building templated code as shared library failed.
Got status 2, result: [ 6%] Building C object
CMakeFiles/model_Constr_SINDy_7.dir/Constr_SINDy_7_model/Constr_SINDy_7_expl_ode_fun.c.obj
[ 12%] Building C object CMakeFiles/model_Constr_SINDy_7.dir/Constr_SINDy_7_model/Constr_SINDy_7_expl_vde_forw.c.obj
[ 18%] Building C object CMakeFiles/model_Constr_SINDy_7.dir/Constr_SINDy_7_model/Constr_SINDy_7_expl_vde_adj.c.obj
[ 18%] Built target model_Constr_SINDy_7
[ 25%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_0_fun.c.obj
[ 31%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_0_fun_jac.c.obj
[ 37%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_0_fun_jac_hess.c.obj
[ 43%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_fun.c.obj
[ 50%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_fun_jac.c.obj
[ 56%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_fun_jac_hess.c.obj
[ 62%] Building C object CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_e_fun.c.obj
mingw32-make.exe[2]: *** [CMakeFiles\ocp_Constr_SINDy_7.dir\build.make:166:
CMakeFiles/ocp_Constr_SINDy_7.dir/Constr_SINDy_7_cost/Constr_SINDy_7_cost_ext_cost_e_fun.c.obj] Error 1
mingw32-make.exe[1]: *** [CMakeFiles\Makefile2:112: CMakeFiles/ocp_Constr_SINDy_7.dir/all] Error 2
mingw32-make.exe: *** [Makefile:135: all] Error 2
Error in AcadosOcpSolver (line 64)
acados_template_mex.compile_ocp_shared_lib(ocp.code_export_directory)
Error in CSINDy_7 (line 73)
Thank in advance.
