Hi,
I have removed the existing build folder from acados root folder and generated build cmake with GENERIC targets as shown below. But still, it crashes.
CMake Warning:
No source or binary directory provided. Both will be assumed to be the
same as the current working directory, but note that this warning will
become a fatal error in future CMake releases.
-- The C compiler identification is AppleClang 14.0.0.14000029
-- The CXX compiler identification is AppleClang 14.0.0.14000029
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Build type is Release
-- ACADOS_WITH_OPENMP: OFF
CMake Deprecation Warning at external/blasfeo/CMakeLists.txt:36 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- The ASM compiler identification is Clang with GNU-like command-line
-- Found assembler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc
-- Using linear algebra: HIGH_PERFORMANCE
-- Using matrix format: PANELMAJ
-- Using external BLAS: 0
-- Testing target GENERIC: assembly compilation [success]
-- Testing target GENERIC: assembly run [success]
-- Testing target GENERIC: intrinsic compilation [success]
-- Testing target GENERIC: intrinsic run [success]
-- Compiling for target: GENERIC
CMake Deprecation Warning at external/hpipm/CMakeLists.txt:36 (cmake_minimum_required):
CMake.
-- Using BLASFEO path:
-- Installation directory: /Users/raghuboppana/acados
-- Target: BLASFEO is GENERIC, HPIPM is GENERIC
-- Linear algebra: HIGH_PERFORMANCE
-- Matlab MEX (OFF)
-- Octave MEX (OFF)
-- Octave Templates (OFF)
-- System name:version Darwin:21.6.0
-- Installation directory is /Users/raghuboppana/acados
-- OpenMP parallelization is OFF
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/raghuboppana/acados
This is what I set in Cmakelists.txt
if(CMAKE_MAKE_PROGRAM)
file(TO_CMAKE_PATH ${CMAKE_MAKE_PROGRAM} CMAKE_MAKE_PROGRAM)
find_program(CMAKE_MAKE_PROGRAM ${CMAKE_MAKE_PROGRAM})
endif()
project(acados LANGUAGES C CXX)
list(APPEND CMAKE_MODULE_PATH "${PROJECT_SOURCE_DIR}/cmake")
set(CMAKE_POSITION_INDEPENDENT_CODE TRUE)
### Defaults
set(ACADOS_INSTALL_DIR "${PROJECT_SOURCE_DIR}" CACHE PATH "Installation path to PROJECT_SOURCE_DIR")
if ("${CMAKE_HOST_SYSTEM_PROCESSOR}" STREQUAL "aarch64")
set(BLASFEO_TARGET "GENERIC" CACHE STRING "BLASFEO Target architecture")
else()
endif()
set(HPIPM_TARGET "GENERIC" CACHE STRING "HPIPM Target architecture")
set(LA "HIGH_PERFORMANCE" CACHE STRING "Linear algebra optimization level")
