Compilation issue with cmake 4.0.3 on mac
Hi guys,
I am trying to compile acados on mac with M1max. I have cmake 4.0.3 and when I try to run it I get this error
zmario@Marios-MacBook-Pro build % cmake -DACADOS_WITH_QPOASES=ON -DACADOS_WITH_QPDUNES=ON -DACADOS_WITH_HPMPC=ON -DACADOS_PYTHON=ON -DACADOS_OCTAVE=ON ..
CMake Error at CMakeLists.txt:35 (cmake_minimum_required):
  Compatibility with CMake < 3.5 has been removed from CMake.
  Update the VERSION argument <min> value.  Or, use the <min>...<max> syntax
  to tell CMake that the project requires at least <min> but has been updated
  to work with policies introduced by <max> or earlier.
  Or, add -DCMAKE_POLICY_VERSION_MINIMUM=3.5 to try configuring anyway.
-- Configuring incomplete, errors occurred!
If I add that flag then I get complaints about not finding malloc or square root.
Hi Mario,
we also had this issue already in our continuous integration and fixed it by adding the -DCMAKE_POLICY_VERSION_MINIMUM=3.5 flag in Fix Github Action errors by FreyJo · Pull Request #1487 · acados/acados · GitHub
I am not aware of further issues about finding functions from standard libraries.
These are probably Mac specific as they didn’t occur on the Linux based CI script with CMake 4.0.
If you could try to find out more about these further issues, it would be highly appreciated.
I would be happy to provide more details, but I do not know how I can do that.
This is what I get:
zmario@Marios-MacBook-Pro build % cmake -DACADOS_WITH_QPOASES=ON -DACADOS_WITH_QPDUNES=ON -DACADOS_WITH_HPMPC=ON -DBLASFEO_TARGET=GENERIC -DACADOS_PYTHON=ON -DACADOS_OCTAVE=ON -DCMAKE_POLICY_VERSION_MINIMUM=3.5 ..
CMake Deprecation Warning at CMakeLists.txt:35 (cmake_minimum_required):
  Compatibility with CMake < 3.10 will be removed from a future version of
  CMake.
-- The C compiler identification is AppleClang 16.0.0.16000026
-- The CXX compiler identification is AppleClang 16.0.0.16000026
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Build type is Release
CMake Deprecation Warning at external/blasfeo/CMakeLists.txt:36 (cmake_minimum_required):
  CMake.
-- The ASM compiler identification is AppleClang
-- Found assembler: /usr/bin/cc
-- Using linear algebra: HIGH_PERFORMANCE
-- Using external BLAS: 0
-- Testing target GENERIC: compilation [success]
-- Testing target GENERIC: run [success]
-- Compiling for target: GENERIC
CMake Deprecation Warning at external/hpipm/CMakeLists.txt:36 (cmake_minimum_required):
  CMake.
-- Using BLASFEO path:
CMake Deprecation Warning at external/hpmpc/CMakeLists.txt:1 (cmake_minimum_required):
  CMake.
CMake Deprecation Warning at external/qpdunes/CMakeLists.txt:49 (CMAKE_MINIMUM_REQUIRED):
  CMake.
CMake Deprecation Warning at external/qpoases/CMakeLists.txt:32 (cmake_minimum_required):
  CMake.
-- Target: BLASFEO is GENERIC, HPIPM is X64_INTEL_HASWELL
-- Linear algebra: HIGH_PERFORMANCE
-- Matlab MEX (OFF)
-- Octave MEX (ON)
-- Octave Templates (OFF)
-- System name:version Darwin:24.0.0
-- Installation directory is /Users/zmario/src/acados
-- Configuring done (1.2s)
-- Generating done (0.1s)
-- Build files have been written to: /Users/zmario/src/acados/build
zmario@Marios-MacBook-Pro build % make
[  1%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Bounds.c.o
/Users/zmario/src/acados/external/qpoases/src/Bounds.c:115:28: error: call to undeclared library function 'malloc' with type 'void *(unsigned long)'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
  115 |     void *raw_memory_ptr = malloc(memory_size);
/Users/zmario/src/acados/external/qpoases/src/Bounds.c:115:28: note: include the header <stdlib.h> or explicitly provide a declaration for 'malloc'
1 error generated.
make[2]: *** [external/qpoases/CMakeFiles/qpOASES_e.dir/src/Bounds.c.o] Error 1
make[1]: *** [external/qpoases/CMakeFiles/qpOASES_e.dir/all] Error 2
make: *** [all] Error 2
Mario
This error is “new” in Clang and it used to be a warning: New warnings and errors in Clang 16. Basically, QPOases should get updated to fix it ideally, or you should be able to pass -std=c89 into the CFLAGS to use the older C89/90 standard where these undeclared functions are allowed.
Thanks Ian, that’s good to know!
@Mario can you try to compile without qpOASES?
Adding some includes in the acados qpOASES version should not be too difficult either.
We usually compile with the c99 standard, so I guess adding -std=c89 will lead to other issues.
I think that the issue is somewhere else. I think that cmake is skipping some information about standard libraries as now the error is with the square root:
zmario@Marios-MacBook-Pro build % cmake -DACADOS_WITH_QPDUNES=ON -DACADOS_WITH_HPMPC=ON -DBLASFEO_TARGET=GENERIC -DACADOS_PYTHON=ON -DACADOS_OCTAVE=ON -DCMAKE_POLICY_VERSION_MINIMUM=3.5 ..
  CMake.
  CMake.
  CMake.
  CMake.
  CMake.
-- Matlab MEX (OFF)
-- Octave MEX (ON)
-- Configuring done (1.3s)
[  0%] Building C object external/qpdunes/CMakeFiles/qpdunes.dir/src/dual_qp.c.o
[  1%] Building C object external/qpdunes/CMakeFiles/qpdunes.dir/src/stage_qp_solver_clipping.c.o
[  1%] Building C object external/qpdunes/CMakeFiles/qpdunes.dir/src/matrix_vector.c.o
[  1%] Building C object external/qpdunes/CMakeFiles/qpdunes.dir/src/setup_qp.c.o
[  2%] Building C object external/qpdunes/CMakeFiles/qpdunes.dir/src/qpdunes_utils.c.o
[  2%] Building C object external/qpdunes/CMakeFiles/qpdunes.dir/interfaces/mpc/setup_mpc.c.o
[  3%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/src/stage_qp_solver_qpoases.cpp.o
[  3%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Bounds.cpp.o
[  4%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Constraints.cpp.o
[  4%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Flipper.cpp.o
[  4%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Indexlist.cpp.o
[  5%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/LoggedSQProblem.cpp.o
[  5%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Matrices.cpp.o
[  6%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/MessageHandling.cpp.o
[  6%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Options.cpp.o
[  7%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/QProblem.cpp.o
[  7%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/QProblemB.cpp.o
[  7%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/SQProblem.cpp.o
[  8%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/SubjectTo.cpp.o
[  8%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/Utils.cpp.o
[  9%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/LAPACKReplacement.cpp.o
[  9%] Building CXX object external/qpdunes/CMakeFiles/qpdunes.dir/externals/qpOASES-3.0beta/src/BLASReplacement.cpp.o
[ 10%] Linking CXX shared library lib/libqpdunes.dylib
[ 10%] Built target qpdunes
[ 11%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/blasfeo_processor_features.c.o
[ 11%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/blasfeo_stdlib.c.o
[ 12%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/d_aux_lib4.c.o
[ 12%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/m_aux_lib44.c.o
[ 13%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/s_aux_lib4.c.o
[ 13%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_daxpy_lib.c.o
[ 13%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_ddot_lib.c.o
[ 14%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgecp_lib4.c.o
[ 14%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgemm_4x4_lib4.c.o
[ 15%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgemm_diag_lib4.c.o
[ 15%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgemv_4_lib4.c.o
[ 16%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgeqrf_4_lib4.c.o
[ 16%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgetr_lib4.c.o
[ 16%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgetrf_pivot_lib4.c.o
[ 17%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dpack_lib4.c.o
[ 17%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_dsymv_4_lib4.c.o
[ 18%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_saxpy_lib.c.o
[ 18%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sdot_lib.c.o
[ 18%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgecp_lib4.c.o
[ 19%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgemm_4x4_lib4.c.o
[ 19%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgemm_diag_lib4.c.o
[ 20%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgemv_4_lib4.c.o
[ 20%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgetr_lib4.c.o
[ 21%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgetrf_pivot_lib4.c.o
[ 21%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_spack_lib4.c.o
[ 21%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/generic/kernel_ssymv_4_lib4.c.o
[ 22%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/kernel/kernel_align_generic.c.o
[ 22%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/d_blas1_lib4.c.o
[ 23%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/d_blas2_diag_lib.c.o
[ 23%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/d_blas2_lib4.c.o
[ 24%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/d_blas3_diag_lib4.c.o
[ 24%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/d_blas3_lib4.c.o
[ 24%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/d_lapack_lib4.c.o
[ 25%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/s_blas1_lib4.c.o
[ 25%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/s_blas2_diag_lib.c.o
[ 26%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/s_blas2_lib4.c.o
[ 26%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/s_blas3_diag_lib4.c.o
[ 27%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/s_blas3_lib4.c.o
[ 27%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blasfeo_api/s_lapack_lib4.c.o
[ 27%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dcopy.c.o
[ 28%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/daxpy.c.o
[ 28%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/ddot.c.o
[ 29%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dgemm.c.o
[ 29%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dsyrk.c.o
[ 29%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dtrmm.c.o
[ 30%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dtrsm.c.o
[ 30%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dgesv.c.o
[ 31%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dgetrf.c.o
[ 31%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dgetrf_np.c.o
[ 32%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dgetrs.c.o
[ 32%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dlaswp.c.o
[ 32%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dposv.c.o
[ 33%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dpotrf.c.o
[ 33%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dpotrs.c.o
[ 34%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/dtrtrs.c.o
[ 34%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/saxpy.c.o
[ 35%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/sdot.c.o
[ 35%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/sgemm.c.o
[ 35%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/blas_api/strsm.c.o
[ 36%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/d_aux_ext_dep_lib.c.o
[ 36%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/d_aux_ext_dep_lib4.c.o
[ 37%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/i_aux_ext_dep_lib.c.o
[ 37%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/s_aux_ext_dep_lib.c.o
[ 38%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/s_aux_ext_dep_lib4.c.o
[ 38%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/timing.c.o
[ 38%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/v_aux_ext_dep_lib.c.o
[ 39%] Linking C shared library libblasfeo.dylib
/usr/bin/cc  -std=c99 -Wall -fdiagnostics-show-option -Wno-error -w -DLA_HIGH_PERFORMANCE -DK_MAX_STACK=300 -DBLAS_API -DUSE_C99_MATH -DEXT_DEP -DMACRO_LEVEL=1 -DOS_MAC -DEXTERNAL_BLAS_NONE -O2 -fPIC -DTARGET_GENERIC  -O3 -DNDEBUG -arch arm64 -dynamiclib -Wl,-headerpad_max_install_names -o libblasfeo.dylib -install_name @rpath/libblasfeo.dylib CMakeFiles/blasfeo.dir/auxiliary/blasfeo_processor_features.c.o CMakeFiles/blasfeo.dir/auxiliary/blasfeo_stdlib.c.o CMakeFiles/blasfeo.dir/auxiliary/d_aux_lib4.c.o CMakeFiles/blasfeo.dir/auxiliary/m_aux_lib44.c.o CMakeFiles/blasfeo.dir/auxiliary/s_aux_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_daxpy_lib.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_ddot_lib.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgecp_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgemm_4x4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgemm_diag_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgemv_4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgeqrf_4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgetr_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dgetrf_pivot_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dpack_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_dsymv_4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_saxpy_lib.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sdot_lib.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgecp_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgemm_4x4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgemm_diag_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgemv_4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgetr_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_sgetrf_pivot_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_spack_lib4.c.o CMakeFiles/blasfeo.dir/kernel/generic/kernel_ssymv_4_lib4.c.o CMakeFiles/blasfeo.dir/kernel/kernel_align_generic.c.o CMakeFiles/blasfeo.dir/blasfeo_api/d_blas1_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/d_blas2_diag_lib.c.o CMakeFiles/blasfeo.dir/blasfeo_api/d_blas2_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/d_blas3_diag_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/d_blas3_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/d_lapack_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/s_blas1_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/s_blas2_diag_lib.c.o CMakeFiles/blasfeo.dir/blasfeo_api/s_blas2_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/s_blas3_diag_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/s_blas3_lib4.c.o CMakeFiles/blasfeo.dir/blasfeo_api/s_lapack_lib4.c.o CMakeFiles/blasfeo.dir/blas_api/dcopy.c.o CMakeFiles/blasfeo.dir/blas_api/daxpy.c.o CMakeFiles/blasfeo.dir/blas_api/ddot.c.o CMakeFiles/blasfeo.dir/blas_api/dgemm.c.o CMakeFiles/blasfeo.dir/blas_api/dsyrk.c.o CMakeFiles/blasfeo.dir/blas_api/dtrmm.c.o CMakeFiles/blasfeo.dir/blas_api/dtrsm.c.o CMakeFiles/blasfeo.dir/blas_api/dgesv.c.o CMakeFiles/blasfeo.dir/blas_api/dgetrf.c.o CMakeFiles/blasfeo.dir/blas_api/dgetrf_np.c.o CMakeFiles/blasfeo.dir/blas_api/dgetrs.c.o CMakeFiles/blasfeo.dir/blas_api/dlaswp.c.o CMakeFiles/blasfeo.dir/blas_api/dposv.c.o CMakeFiles/blasfeo.dir/blas_api/dpotrf.c.o CMakeFiles/blasfeo.dir/blas_api/dpotrs.c.o CMakeFiles/blasfeo.dir/blas_api/dtrtrs.c.o CMakeFiles/blasfeo.dir/blas_api/saxpy.c.o CMakeFiles/blasfeo.dir/blas_api/sdot.c.o CMakeFiles/blasfeo.dir/blas_api/sgemm.c.o CMakeFiles/blasfeo.dir/blas_api/strsm.c.o CMakeFiles/blasfeo.dir/auxiliary/d_aux_ext_dep_lib.c.o CMakeFiles/blasfeo.dir/auxiliary/d_aux_ext_dep_lib4.c.o CMakeFiles/blasfeo.dir/auxiliary/i_aux_ext_dep_lib.c.o CMakeFiles/blasfeo.dir/auxiliary/s_aux_ext_dep_lib.c.o CMakeFiles/blasfeo.dir/auxiliary/s_aux_ext_dep_lib4.c.o CMakeFiles/blasfeo.dir/auxiliary/timing.c.o CMakeFiles/blasfeo.dir/auxiliary/v_aux_ext_dep_lib.c.o
[ 39%] Built target blasfeo
[ 39%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/d_cast_qcqp.c.o
[ 40%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/d_cond.c.o
[ 40%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/d_cond_aux.c.o
[ 41%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/d_cond_qcqp.c.o
[ 41%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/d_part_cond.c.o
[ 41%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/d_part_cond_qcqp.c.o
[ 42%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/s_cast_qcqp.c.o
[ 42%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/s_cond.c.o
[ 43%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/s_cond_aux.c.o
[ 43%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/s_cond_qcqp.c.o
[ 43%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/s_part_cond.c.o
[ 44%] Building C object external/hpipm/CMakeFiles/hpipm.dir/cond/s_part_cond_qcqp.c.o
[ 44%] Building C object external/hpipm/CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp.c.o
[ 45%] Building C object external/hpipm/CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_dim.c.o
[ 45%] Building C object external/hpipm/CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_ipm.c.o
In file included from /Users/zmario/src/acados/external/hpipm/dense_qp/d_dense_qcqp_ipm.c:212:
/Users/zmario/src/acados/external/hpipm/dense_qp/x_dense_qcqp_ipm.c:843:18: error: call to undeclared library function 'sqrt' with type 'double (double)'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
  843 |         REAL sqrt_mu0 = sqrt(mu0);
/Users/zmario/src/acados/external/hpipm/dense_qp/x_dense_qcqp_ipm.c:843:18: note: include the header <math.h> or explicitly provide a declaration for 'sqrt'
1 error generated.
make[2]: *** [external/hpipm/CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_ipm.c.o] Error 1
make[1]: *** [external/hpipm/CMakeFiles/hpipm.dir/all] Error 2
The file it complains about now seems to be missing an #include <math.h>.
Alternatively, you might try with another compiler to decouple the new cmake and clang issues.
Yeah, I got that, but I doubt that the code is missing that include command. I think that probably cmake didn’t do its job correctly, or am I missing something?
That is a weirder error, because from what I can tell, it should be including the math header inside d_dense_qcqp_ipm when USE_C99_MATH is true - which it appears to be because the earlier link line included it. Those line numbers don’t match with teh HPIPM that is currently in Acados master though, so which version are you trying?
I tried a fresh clone and now I get this error:
zmario@Marios-MacBook-Pro build % cmake -DACADOS_WITH_QPOASES=ON -DACADOS_WITH_QPDUNES=ON -DACADOS_WITH_HPMPC=ON -DBLASFEO_TARGET=ARMV8A_APPLE_M1 -DACADOS_PYTHON=ON -DCMAKE_POLICY_VERSION_MINIMUM=3.5 ..
CMake Deprecation Warning at CMakeLists.txt:32 (cmake_minimum_required):
  CMake.
-- ACADOS_WITH_OPENMP: OFF
  CMake.
-- Using matrix format: PANELMAJ
-- Testing target ARMV8A_APPLE_M1: assembly compilation [success]
-- Testing target ARMV8A_APPLE_M1: assembly run [success]
-- Testing target ARMV8A_APPLE_M1: intrinsic compilation [success]
-- Testing target ARMV8A_APPLE_M1: intrinsic run [success]
-- Compiling for target: ARMV8A_APPLE_M1
  CMake.
-- HPIPM Target is GENERIC
-- Installation directory: /Users/zmario/src/acados
  CMake.
  CMake.
  CMake.
-- Target: BLASFEO is ARMV8A_APPLE_M1, HPIPM is GENERIC
-- Octave MEX (OFF)
-- OpenMP parallelization is OFF
zmario@Marios-MacBook-Pro build % make install
[  0%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Bounds.c.o
[  1%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Constraints.c.o
[  1%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Flipper.c.o
[  1%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Indexlist.c.o
[  2%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Matrices.c.o
[  2%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/MessageHandling.c.o
[  2%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/OQPinterface.c.o
[  3%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Options.c.o
[  3%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/QProblem.c.o
[  3%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/QProblemB.c.o
[  4%] Building C object external/qpoases/CMakeFiles/qpOASES_e.dir/src/Utils.c.o
[  4%] Linking C shared library lib/libqpOASES_e.dylib
[  4%] Built target qpOASES_e[ 30%] Building C object external/blasfeo/CMakeFiles/blasfeo.dir/auxiliary/s_aux_ext_dep_common.c.o
[ 56%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_sol.c.o
[ 57%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_utils.c.o
[ 57%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp.c.o
[ 57%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_dim.c.o
[ 58%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_ipm.c.o
[ 58%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_kkt.c.o
[ 58%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_res.c.o
[ 59%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_sol.c.o
[ 59%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_utils.c.o
[ 59%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp.c.o
[ 60%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_dim.c.o
[ 60%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_ipm.c.o
[ 60%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_res.c.o
[ 61%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_sol.c.o
[ 61%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_utils.c.o
[ 61%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp.c.o
[ 62%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_dim.c.o
[ 62%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_ipm.c.o
[ 62%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_kkt.c.o
[ 63%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_res.c.o
[ 63%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_sol.c.o
[ 63%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_utils.c.o
[ 64%] Building C object external/hpipm/CMakeFiles/hpipm.dir/tree_ocp_qp/scenario_tree.c.o
[ 64%] Building C object external/hpipm/CMakeFiles/hpipm.dir/auxiliary/aux_mem.c.o
[ 64%] Building C object external/hpipm/CMakeFiles/hpipm.dir/auxiliary/aux_string.c.o
[ 65%] Building C object external/hpipm/CMakeFiles/hpipm.dir/auxiliary/timing.c.o
[ 65%] Linking C shared library libhpipm.dylib
/usr/bin/cc  -std=c99 -Wall -fdiagnostics-show-option -Wno-error -w -DTARGET_GENERIC  -DUSE_C99_MATH -DRUNTIME_CHECKS -O3 -DNDEBUG -arch arm64 -dynamiclib -Wl,-headerpad_max_install_names -o libhpipm.dylib -install_name @rpath/libhpipm.dylib CMakeFiles/hpipm.dir/cond/d_cast_qcqp.c.o CMakeFiles/hpipm.dir/cond/d_cond.c.o CMakeFiles/hpipm.dir/cond/d_cond_aux.c.o CMakeFiles/hpipm.dir/cond/d_cond_qcqp.c.o CMakeFiles/hpipm.dir/cond/d_part_cond.c.o CMakeFiles/hpipm.dir/cond/d_part_cond_qcqp.c.o CMakeFiles/hpipm.dir/cond/s_cast_qcqp.c.o CMakeFiles/hpipm.dir/cond/s_cond.c.o CMakeFiles/hpipm.dir/cond/s_cond_aux.c.o CMakeFiles/hpipm.dir/cond/s_cond_qcqp.c.o CMakeFiles/hpipm.dir/cond/s_part_cond.c.o CMakeFiles/hpipm.dir/cond/s_part_cond_qcqp.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_dim.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_ipm.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_res.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_sol.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qcqp_utils.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_dim.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_ipm.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_kkt.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_res.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_seed.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_sol.c.o CMakeFiles/hpipm.dir/dense_qp/d_dense_qp_utils.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qcqp.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qcqp_dim.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qcqp_ipm.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qcqp_res.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qcqp_sol.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qcqp_utils.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_dim.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_ipm.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_kkt.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_res.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_seed.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_sol.c.o CMakeFiles/hpipm.dir/dense_qp/s_dense_qp_utils.c.o CMakeFiles/hpipm.dir/ipm_core/d_core_qp_ipm.c.o CMakeFiles/hpipm.dir/ipm_core/d_core_qp_ipm_aux.c.o CMakeFiles/hpipm.dir/ipm_core/s_core_qp_ipm.c.o CMakeFiles/hpipm.dir/ipm_core/s_core_qp_ipm_aux.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qcqp.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qcqp_dim.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qcqp_ipm.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qcqp_res.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qcqp_sol.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qcqp_utils.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_dim.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_ipm.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_kkt.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_red.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_res.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_seed.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_sol.c.o CMakeFiles/hpipm.dir/ocp_qp/d_ocp_qp_utils.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qcqp.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qcqp_dim.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qcqp_ipm.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qcqp_res.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qcqp_sol.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qcqp_utils.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_dim.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_ipm.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_kkt.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_red.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_res.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_seed.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_sol.c.o CMakeFiles/hpipm.dir/ocp_qp/s_ocp_qp_utils.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_dim.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_ipm.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_res.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_sol.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qcqp_utils.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_dim.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_ipm.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_kkt.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_res.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_sol.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/d_tree_ocp_qp_utils.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_dim.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_ipm.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_res.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_sol.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qcqp_utils.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_dim.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_ipm.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_kkt.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_res.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_sol.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/s_tree_ocp_qp_utils.c.o CMakeFiles/hpipm.dir/tree_ocp_qp/scenario_tree.c.o CMakeFiles/hpipm.dir/auxiliary/aux_mem.c.o CMakeFiles/hpipm.dir/auxiliary/aux_string.c.o CMakeFiles/hpipm.dir/auxiliary/timing.c.o  -Wl,-rpath,/Users/zmario/src/acados/build/external/blasfeo ../blasfeo/libblasfeo.dylib
[ 65%] Built target hpipm
[ 65%] Building C object external/hpmpc/CMakeFiles/hpmpc.dir/auxiliary/d_aux_extern_depend_lib4.c.o
[ 66%] Building C object external/hpmpc/CMakeFiles/hpmpc.dir/auxiliary/d_aux_lib4.c.o
[ 66%] Building C object external/hpmpc/CMakeFiles/hpmpc.dir/auxiliary/i_aux.c.o
[ 66%] Building C object external/hpmpc/CMakeFiles/hpmpc.dir/lqcp_solvers/d_back_ric_rec_libstr.c.o
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:145:105: error: too many arguments to function call, expected 8, have 9
  145 |                         blasfeo_dtrmv_lnn(nx[N-nn], nx[N-nn], &hsL[N-nn], nu[N-nn], nu[N-nn], &hswork_vec_0, 0, &hsPb[N-nn], 0);
/Users/zmario/src/acados/external/blasfeo/include/blasfeo_d_blasfeo_api.h:105:6: note: 'blasfeo_dtrmv_lnn' declared here
  105 | void blasfeo_dtrmv_lnn(int m, struct blasfeo_dmat *sA, int ai, int aj, struct blasfeo_dvec *sx, int xi, struct blasfeo_dvec *sz, int zi);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:198:102: error: too many arguments to function call, expected 8, have 9
  198 |                 blasfeo_dtrmv_ltn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hspi[nn+1], 0, &hspi[nn+1], 0);
/Users/zmario/src/acados/external/blasfeo/include/blasfeo_d_blasfeo_api.h:109:6: note: 'blasfeo_dtrmv_ltn' declared here
  109 | void blasfeo_dtrmv_ltn(int m, struct blasfeo_dmat *sA, int ai, int aj, struct blasfeo_dvec *sx, int xi, struct blasfeo_dvec *sz, int zi);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:200:102: error: too many arguments to function call, expected 8, have 9
  200 |                 blasfeo_dtrmv_lnn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hspi[nn+1], 0, &hspi[nn+1], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:217:103: error: too many arguments to function call, expected 8, have 9
  217 |                         blasfeo_dtrmv_ltn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hspi[nn+1], 0, &hspi[nn+1], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:219:103: error: too many arguments to function call, expected 8, have 9
  219 |                         blasfeo_dtrmv_lnn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hspi[nn+1], 0, &hspi[nn+1], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:340:104: error: too many arguments to function call, expected 8, have 9
  340 |                         blasfeo_dtrmv_ltn(nx[N-nn], nx[N-nn], &hsL[N-nn], nu[N-nn], nu[N-nn], &hsb[N-nn-1], 0, &hsPb[N-nn], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:341:103: error: too many arguments to function call, expected 8, have 9
  341 |                         blasfeo_dtrmv_lnn(nx[N-nn], nx[N-nn], &hsL[N-nn], nu[N-nn], nu[N-nn], &hsPb[N-nn], 0, &hsPb[N-nn], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:364:103: error: too many arguments to function call, expected 8, have 9
  364 |                 blasfeo_dtrmv_ltn(nx[N-nn], nx[N-nn], &hsL[N-nn], nu[N-nn], nu[N-nn], &hsb[N-nn-1], 0, &hsPb[N-nn], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:365:102: error: too many arguments to function call, expected 8, have 9
  365 |                 blasfeo_dtrmv_lnn(nx[N-nn], nx[N-nn], &hsL[N-nn], nu[N-nn], nu[N-nn], &hsPb[N-nn], 0, &hsPb[N-nn], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:395:106: error: too many arguments to function call, expected 8, have 9
  395 |                 blasfeo_dtrmv_ltn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hswork_vec_0, 0, &hswork_vec_0, 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:396:106: error: too many arguments to function call, expected 8, have 9
  396 |                 blasfeo_dtrmv_lnn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hswork_vec_0, 0, &hswork_vec_0, 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:416:107: error: too many arguments to function call, expected 8, have 9
  416 |                         blasfeo_dtrmv_ltn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hswork_vec_0, 0, &hswork_vec_0, 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:417:107: error: too many arguments to function call, expected 8, have 9
  417 |                         blasfeo_dtrmv_lnn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hswork_vec_0, 0, &hswork_vec_0, 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:497:105: error: too many arguments to function call, expected 8, have 9
  497 |                         blasfeo_dtrmv_lnn(nx[N-nn], nx[N-nn], &hsL[N-nn], nu[N-nn], nu[N-nn], &hswork_vec_0, 0, &hsPb[N-nn], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:567:103: error: too many arguments to function call, expected 8, have 9
  567 |                         blasfeo_dtrmv_ltn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hspi[nn+1], 0, &hspi[nn+1], 0);
/Users/zmario/src/acados/external/hpmpc/lqcp_solvers/d_back_ric_rec_libstr.c:569:103: error: too many arguments to function call, expected 8, have 9
  569 |                         blasfeo_dtrmv_lnn(nx[nn+1], nx[nn+1], &hsL[nn+1], nu[nn+1], nu[nn+1], &hspi[nn+1], 0, &hspi[nn+1], 0);
16 errors generated.
make[2]: *** [external/hpmpc/CMakeFiles/hpmpc.dir/lqcp_solvers/d_back_ric_rec_libstr.c.o] Error 1
make[1]: *** [external/hpmpc/CMakeFiles/hpmpc.dir/all] Error 2
I had to remove some lines to make the message fit
I managed to compile with
cmake -DACADOS_WITH_QPOASES=ON -DACADOS_OCTAVE=ON -DACADOS_PYTHON=ON -DCMAKE_POLICY_VERSION_MINIMUM=3.5 ..
but I could not compile HPMPC nor qpDUNES. HPMPC throws these errors:
[ 72%] Building C object external/hpmpc/CMakeFiles/hpmpc.dir/lqcp_solvers/d_back_ric_rec_libstr.c.o
qpDUNES throws this error:
[ 88%] Building C object acados/CMakeFiles/acados.dir/ocp_qp/ocp_qp_qpdunes.c.o
In file included from /Users/zmario/src/acados/acados/ocp_qp/ocp_qp_qpdunes.c:48:
In file included from /Users/zmario/src/acados/acados/utils/print.h:40:
In file included from /Users/zmario/src/acados/acados/ocp_nlp/ocp_nlp_common.h:59:
In file included from /Users/zmario/src/acados/acados/ocp_nlp/ocp_nlp_dynamics_common.h:51:
In file included from /Users/zmario/src/acados/acados/sim/sim_common.h:38:
In file included from /Users/zmario/src/acados/acados/utils/timing.h:56:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/mach_time.h:32:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/mach_types.h:80:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/host_info.h:66:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/message.h:78:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/port.h:91:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/boolean.h:73:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/machine/boolean.h:35:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/mach/arm/boolean.h:70:25: error: typedef redefinition with different types ('int' vs 'unsigned int')
   70 | typedef int             boolean_t;
/Users/zmario/src/acados/external/qpdunes/include/qp/types.h:151:23: note: previous definition is here
  151 |         typedef unsigned int boolean_t;
1 error generated.
make[2]: *** [acados/CMakeFiles/acados.dir/ocp_qp/ocp_qp_qpdunes.c.o] Error 1
make[1]: *** [acados/CMakeFiles/acados.dir/all] Error 2
Hi Mario,
Does the compilation work without these two QP solvers?
Regarding HPMPC:
Probably, we should deprecate HPMPC in acados, or make HPMPC compatible with newer BLASFEO versions.
HPIPM implements the same algorithms.
It seems that there were some breaking API changes in BLASFEO, which are not compatible with HPMPC.
On the other hand, having recent HPIPM version in acados is important and they require new BLASFEO versions.
Actually, the last commit in HPMPC is from me fixing a BLASFEO API change 4 years ago.
Regarding the qpDUNES issue, probably renaming:
boolean_t to qpdunes_boolean_t would be the best fix.
Right, I was actually wondering where HPIPM was, so it’s there by default. For qpDUNES I don’t think the best is if I fix it on my own, maybe the best is if this is done in a principled way, but thoroughly checking that the change fixes it across platforms. Anyway, HPIPM is enough at the moment for what I need to do.
Mario
The CMake issues are resolved with Update HPIPM & BLASFEO by FreyJo · Pull Request #1577 · acados/acados · GitHub
The -DCMAKE_POLICY_VERSION_MINIMUM=3.5 is not needed anymore.
