I want to set a custom code_export_directory for my AcadosMultiphaseOcp, but it seems like when I specify the code_export_directory attribute, some of the generated code is still put into the default code_export_directory (c_generated_code). I pasted an example below:
Here is a function that exports the double integrator model, in a file called “acados_double_integrator_model.py”.
from casadi import SX, vertcat, sin, cos
def export_double_integrator_model(dim_q, dt) -> AcadosModel:
model_name = 'double_integrator_disc_dyn'
# set up states & controls
q = SX.sym('q', dim_q)
v = SX.sym('v', dim_q)
x = vertcat(q, v)
u = SX.sym('u', dim_q)
vnext = v + u*dt
qnext = q + vnext*dt
model.disc_dyn_expr = vertcat(qnext, vnext)
model.x = x
model.u = u
model.name = model_name
return model
The script that imports the above function is called “double_integrator_multiphase_example.py”, pasted below:
from acados_template import AcadosOcp, AcadosOcpSolver, AcadosMultiphaseOcp
from acados_double_integrator_model import export_double_integrator_model
from casadi import Function
def main():
# Horizon definition
N = 20 # Number of time intervals
Tf = 1.0 # Duration
dt = Tf/N # Time step
# Dimension of double integrator configuration and velocity
nq = 1
nv = 1
# State and control dimensions
nx = nq + nv
nu = nv
# Initial state
x0 = np.concatenate((np.ones(nq), 0.25*np.ones(nv)))
# Cost matrices
Q_mat = np.diag(np.concatenate((np.ones(nq), 10*np.ones(nv))))
R_mat = np.diag(10*np.ones(nu))
# Number of intervals in each phase
N_list = [10, 10]
# Multiphase ocp
multiphase_ocp = AcadosMultiphaseOcp(N_list=N_list)
#### PHASE 0: velocity can take any value ####
# Dynamics
phase_idx = 0
acados_model = export_double_integrator_model(nq, dt)
ocp.model = acados_model
ocp.dims.N = N_list[phase_idx]
# Quadratic state and control cost
ocp.model.cost_expr_ext_cost = acados_model.x.T @ Q_mat @ acados_model.x + acados_model.u.T @ R_mat @ acados_model.u
ocp.model.cost_expr_ext_cost_e = acados_model.x.T @ Q_mat @ acados_model.x
# Control limits
Fmax = 1
ocp.constraints.lbu = -Fmax*np.ones(nu)
ocp.constraints.ubu = Fmax*np.ones(nu)
# Initial state constraint
ocp.constraints.x0 = x0
ocp.code_export_directory = 'c_generated_code_double_integrator'
multiphase_ocp.set_phase(ocp, phase_idx)
#### PHASE 1: velocity must be nonpositive ####
phase_idx += 1
# Dynamics
# Nonlinear constraint: velocity must be nonpositive (yes, this is actually
# a linear constraint, but we're enforcing it using the acados nonlinear constraint interface)
h_expr = acados_model.x[nq:]
h_lb = -10*np.ones(nv)
h_ub = np.zeros(nv)
acados_model.con_h_expr = h_expr
# Control limits
Fmax = 1
# Set nonlinear constraint sizes and bounds
ocp.dims.nh = h_expr.shape[0]
ocp.constraints.lh = h_lb
ocp.constraints.uh = h_ub
# Set options
multiphase_ocp.solver_options.qp_solver = 'PARTIAL_CONDENSING_HPIPM'
multiphase_ocp.solver_options.qp_solver_cond_N = N
multiphase_ocp.solver_options.hessian_approx = 'GAUSS_NEWTON'
multiphase_ocp.solver_options.nlp_solver_type = 'SQP'
multiphase_ocp.solver_options.tf = Tf
multiphase_ocp.solver_options.nlp_solver_tol_eq = 1e-4
multiphase_ocp.solver_options.nlp_solver_tol_ineq = 1e-4
multiphase_ocp.mocp_opts.integrator_type = ['DISCRETE', 'DISCRETE']
multiphase_ocp.code_export_directory = 'c_generated_code_double_integrator'
ocp_solver = AcadosOcpSolver(multiphase_ocp, json_file = 'acados_ocp_double_integrator.json')
status = ocp_solver.solve()
ocp_solver.print_statistics() # encapsulates: stat = ocp_solver.get_stats("statistics")
if __name__ == '__main__':
main()
When I run the script (i.e. using
python3 double_integrator_multiphase_example.py
in the terminal, I get the error
make: *** No rule to make target 'double_integrator_disc_dyn_0_cost/double_integrator_disc_dyn_0_cost_ext_cost_fun.o', needed by 'ocp_shared_lib'. Stop.
The c_generated_code_double_integrator directory is generated, but the double_integrator_disc_dyn_0_cost directory is still put into the c_generated_code directory, which I think is the issue. I’m able to specify custom export directories with the non-multiphase interface just fine.
Thanks,
Anoop
