Acados Pre-release v0.1.3
There is a new pre-release of acados, version 0.1.3
This is meant to give an overview on the changes from the last 6 months.
Changes since the previous release 0.1.2
General
Interfaces
Bugfixes:
This is great!
Thank you very much for the great job!
Cheers
Armin
First of all, congratulations to this great software!
I just downloaded acados on my second machine and I had troubles running the minimal_example_ocp. I always got a lot of errors which stated undefined reference to 'omp_get_num_threads' . After some research I found out, that this has to do with the OpenMP Library. It seems, that you have to set an extra flag -fopenmp or -openmp when compiling.
I resolved the problem with disabling the OpenMP support while performing cmake, hence,
 cmake.exe -G "MinGW Makefiles" -DACADOS_WITH_OPENMP=OFF -D BLASFEO_TARGET=GENERIC -D HPIPM_TARGET=GENERIC -D ACADOS_INSTALL_DIR=.. -DBUILD_SHARED_LIBS=OFF -DACADOS_EXAMPLES=OFF  -DACADOS_UNIT_TESTS=OFF ..
Note: I’m working with Windows 10 and MATLAB R2020a
Thanks for reporting this issue.
Checking for availability of OpenMP and setting the appropriate flags should happen here:
Note, it was also tested on Windows here.
Maybe you can try to run a C example to check if it is related to Matlab.
Otherwise, for now setting, -DACADOS_WITH_OPENMP=OFF, is the way to go.
