Acados featured work collection
Dear acados Community,
we are happy to have helped a number of people to use acados for their application via this forum.
We would like to start maintaining a public list of projects and publications (papers, thesis, benchmarks, etc) that feature acados.
This thread is meant for you to submit links, documents, or code repositories that might be interesting for other users in the future.
We are looking forward to getting to know more about your work.
Thanks a lot :pray:
Jonathan & The acados developers.
this is a very good idea. Here are two of my papers where I have successfully used acados:
Contraction Properties of the Advanced Step Real-Time Iteration for NMPC at the IFAC World Congress 2020 : https://cdn.syscop.de/publications/Nurkanovic2020b.pdf
Real-Time Nonlinear Model Predictive Control for Microgrid Operation at the American Control Conference 2020: https://cdn.syscop.de/publications/Nurkanovic2020a.pdf
I have one more paper where I have used acados, which is not yet published. However, here is a link to the prepreint: https://www.researchgate.net/publication/341622767_Optimization-based_Primary_and_Secondary_Control_of_Microgrids
Cheers
Armin
Hi Jonathan and Acados dev team !
Once again, thanks for the great work. We are currently developing a library for optimal control in Biomechanics (https://github.com/pyomeca/bioptim). Ipopt and Acados are now (almost) fully interfaced. Publications and benchmarks are in progress !
François
Hi Jonathan and developers,
thanks for the great user support!
I have written a Python library for economic tuning of tracking NMPC problems (TuneMPC - https://github.com/jdeschut/tunempc). It computes positive definite stage cost matrices for a tracking NMPC problem so that it’s feedback policy locally approximates that of economic NMPC around an economically optimal reference.
Using the acados Python interface, TuneMPC provides the possibility to automatically formulate and code-generate the “tuned” tracking MPC solvers (as well as economic and standard tracking MPC for comparison).
The paper can be found here.
Jochem
here are some of my papers using acados:
An Efficient Real-Time NMPC for Quadrotor Position Control under Communication Time-Delay: https://arxiv.org/abs/2010.11264
Least Conservative Linearized Constraint Formulation for Real-Time Motion Generation: https://www.dis.uniroma1.it/~labrob/pub/papers/IFAC20_RealTimeMotiongeneration_preprint.pdf
Bárbara
Thanks to everybody posting here! :pray:
The list can be found here:
https://docs.acados.org/list_of_projects/index.html
Hey Jonathan,
Thank you very much for this great software framework!
I successfully used acados for the following paper:
Model predictive control of wind turbine fatigue via online rainflow-counting on stress history and prediction at the wind energy conference TORQUE 2020: https://iopscience.iop.org/article/10.1088/1742-6596/1618/2/022041
Best regards,
Stefan
Some update on our Python framework for biomechanical optimal control based on acados (among others):
https://www.biorxiv.org/content/10.1101/2021.02.27.432868v1
François
First of all many thanks for this great solver framework!
I just published the code, which makes use of acados in two shared controllers (C++/ROS) for vehicle teleoperation.
The code even made it on a F1TENTH vehicle. You can see it in action in videos, linked in the README under Demonstrations of Operator in the Experiments.
There also exists a related publication.
“Steering Action-aware Adaptive Cruise Control for Teleoperated Driving”
Greetings from TUM,
Andreas
Hi acados team,
Thank you so much for developing such an amazing tool!
Here is our CDC23 paper using acados:
Nonlinear MPC for Quadrotors in Close-Proximity Flight with Neural Network Downwash Prediction: https://arxiv.org/abs/2304.07794
Jinjie
I found the acados installation - having to manually set environment variables and installing t_renderer on-the-fly - a bit cumbersome and difficult to maintain as a dependency in larger projects. So packaged acados, acados_template and t_renderer for nix:
You don’t need nixos, just any system with nix installed (one-liner). You can then get a shell with all required packages by running:
nix shell github:adrian-kriegel/acados-nix#acados-dev
No need to manually install dependencies, virtualenvs or to set LD_LIBRARY_PATH and ACADOS_SOURCE_DIR.
Recently, I used acados a lot with ROS2, therefore I created a ROS2 node code generator ros_acados_nodegen. This package uses the generated json of the solver and can be simply installed with pip. It is an entry point for the usage of ROS2 with acados and not a fully functional node. You still need to process the specified published topics as well as subscriptions to states, inputs etc…
The package also comes with a acados installation script that can be used after installation of this package.
thanks for the great package. I recently got my ICRA paper accepted, featuring a combination of acados and flow matching for safe manipulator motion planning.
You can find the resources here:
Paper: [2602.12794] SafeFlowMPC: Predictive and Safe Trajectory Planning for Robot Manipulators with Learning-based Policies
Code: GitHub - TU-Wien-ACIN-CDS/SafeFlowMPC: SafeFlowMPC: Predictive and Safe Trajectory Planning for Robot Manipulators with Learning-based Policies (Published at ICRA 2026)
Video: SafeFlowMPC: Predictive and Safe Trajectory Planning for Robot Manipulators with Learning-based Policies – Automation & Control Institute
Best
Thies
