I am using the Python interface to solve a boundary value problem via multiple shooting method.
The ordinary differential equations implemented are discretized w.r.t. an arc length instead of time.
I wrote a code solver to determine the best subset of initial conditions such that the boundary conditions can be minimised.
However, solving the NLP will always result in the QP solver return error status 3.
I have tried the following:
- Setting an approximately close solution for an initial guess for all stages.
- Setting a regularization term.
- Checking the cost function.
If it helps, the multiple shooting problem is formulated into an OCP solver as such:
self.ocp = AcadosOcp()
self.ocp.model = self.tetherObject.model
nx = self.tetherObject.model.x.size()[0]
nu = self.tetherObject.model.u.size()[0]
ny = nx + nu
self.ocp.dims.N = self.integration_steps
# self.ocp.cost.cost_type_0 = 'LINEAR_LS'
# self.ocp.cost.cost_type = 'LINEAR_LS'
self.ocp.cost.cost_type_e = 'LINEAR_LS'
self.ocp.cost.W_e = np.identity(nx)
self.ocp.cost.W = np.zeros((ny, ny))
self.ocp.cost.Vx = np.zeros((ny, nx))
self.ocp.cost.Vx_e = np.zeros((nx, nx))
self.ocp.cost.Vx_e[0:7, 0:7] = np.identity(7)
self.ocp.cost.yref = np.zeros((ny, ))
self.ocp.cost.yref_e = np.zeros((nx))
self.ocp.cost.Vu = np.zeros((ny, nu))
self.ocp.solver_options.qp_solver_iter_max = 400
# self.ocp.solver_options.sim_method_num_steps = self.integration_steps
self.ocp.solver_options.qp_solver_warm_start = 2
self.ocp.solver_options.levenberg_marquardt = 1.0
self.ocp.solver_options.regularize_method = 'MIRROR'
self.ocp.solver_options.qp_solver = 'PARTIAL_CONDENSING_HPIPM' #
# PARTIAL_CONDENSING_HPIPM, FULL_CONDENSING_QPOASES, FULL_CONDENSING_HPIPM,
# PARTIAL_CONDENSING_QPDUNES, PARTIAL_CONDENSING_OSQP, FULL_CONDENSING_DAQP
self.ocp.solver_options.hessian_approx = 'GAUSS_NEWTON'
self.ocp.solver_options.integrator_type = 'ERK'
# self.ocp.solver_options.print_level = 1
self.ocp.solver_options.nlp_solver_type = 'SQP_RTI' # SQP_RTI, SQP
self.ocp.solver_options.tf = self.boundary_length
wrench_lb = -2
wrench_ub = 2
self.ocp.constraints.idxbx_0 = np.array([0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16])
self.ocp.constraints.lbx_0 = np.array([0, 0, 0, 1, 0, 0, 0, #pose at start.
wrench_lb , wrench_lb , wrench_lb , wrench_lb , wrench_lb , wrench_lb , # internal forces at start.
0, 0, 0.05, 0]) #tau, alpha, kappa, curvature
self.ocp.constraints.ubx_0 = np.array([0, 0, 0, 1, 0, 0, 0, #pose at start.
wrench_ub , wrench_ub , wrench_ub , wrench_ub , wrench_ub , wrench_ub , # internal forces at start.
self.ocp.constraints.idxbx = np.array([0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16])
self.ocp.constraints.lbx = np.array([-5, -5, -5, -1.05, -1.05, -1.05, -1.05, #pose at start.
-20, 0, 0.05, 0]) #tau, alpha, kappa, curvature
self.ocp.constraints.ubx = np.array([5, 5, 5, 1.05, 1.05, 1.05, 1.05, #pose at start.
20, self.boundary_length, 0.05, 50]) #tau, alpha, kappa, curvature
self.ocp.solver_options.nlp_solver_max_iter = 200
solver = AcadosOcpSolver(self.ocp, json_file=f'{self.ocp.model.name}.json')
integrator = AcadosSimSolver(self.ocp, json_file=f'{self.ocp.model.name}.json')
return solver, integrator
Printing the residuals and statistics from the solver (when putting an approximate solution) gives:
[1.00054985e+00 0.00000000e+00 3.12768808e-01 9.26639719e-09]
iter qp_stat qp_iter
0 0 0
1 0 4
Without using an approximate solution, I get:
[2.2000000e+00 1.1996702e+35 5.0000000e+01 0.0000000e+00]
0 0 0
1 3 1
Thanks for the help.
Jer Luen
